Is there a way to adjust the output encoding quality? The output video looks good, but I do notice that the compression is much higher than the source material. Thanks!
The bit rate is hardcoded at 8M bps.
Is it possible that this may be a parameter in the future? The GoPro 10 5.3K source files will be ~60M bps, right?
Yes, I can add that as a parameter in the next release.
Gchen I’m really looking forward to all the updates you have in the works. Thank you for all your work.
