Audio quality settings?
Hi. Using 2 GoPro 11s. Is there a way to set the audio output quality for the stitched video? I know there is an option to select no audio, but what about reducing the quality? High audio quality is not important in my stitched video, but some low level audio makes watching the video more realistic. I am thinking a reduced audio quality would reduce processing time also lower the file size output. Is there something similar to how the video bitrate is set using Regedit. Thanks
This is not currently supported. You can use ffmpeg to lower the audio quality. However, if your main goal is to reduce the file size, I doubt the audio quality would have a significant impact on the size – the size of the audio stream is negligible when compared with that of the video stream.
