Basic setting for GoPro Hero 10
Hello everyone,
I am a beginner !
I don’t find any info about the basic settings for a GoPro 10 Hero, for example, do I need to use Tripod mode? 4K or 5.3K? 30p or 60 P etc… Do the GoPro record 45 minutes straight or it creating different files. I need help please! I would like to have this info before to buy the license! Thank you everyone!
Tripod mode would be the best. 5.3K and 30 fps. GoPro can record 45 minutes with internal battery but it can go much longer if connected to a power bank. It will create a number of video files – in ActionStich you can select all of them at once so you don’t need to combine them into a single file first.
Thank you ! I bought the license but I don’t know how to put the license. I am using a Mac, version 12.7.6.
The ActionStitch is not showing any toolbar.
Thank you!
You can find the ActionStitch icon on the menu bar (which is usually on the top right corner of the screen). Right click the icon you’ll see a menu item saying ‘About’. Choose that and the About dialog will show up which allows you to enter the license code.
Great Thank you, quick question I loaded the video file, I aligned the audio, pushed sync BUT now I can no set the first frame. help please!
This is from Software Guide:
  • Set first frame: now you can set the current frame being played as the starting frame of the stitched video. You can also set the first frame by dragging the left end of the blue bar in the video control.
Please note that how the blue bar under the video players changes after you click the ‘Set first frame’ button. This blue bar indicates the beginning and ending of the stitched videos and can be controlled by the ‘Set first frame’ and ‘Set last frame’ buttons.
Hi yes, read the manual but nothing happens. Do you have any video on YouTube?
sorry my bad, I never select the camera as an option
