As title says can I capture 4k 60fps on using both one rs 4k boost and recommended gamsod 4k fps camera? Plus what mounts should I use and are there 3d printer templates that can hold both these different cameras?
I’ve opened the free trial actionstitch but I can’t seem to see the one rs as an option for the camera.
Theoretically it is possible. However, I’m not sure if Insta360 One RS 4k can be used to record a soccer game. I own one and remember in a test it only lasted 30 minutes due to overheating. Try run a test yourself to see if it can record for more than an hour. If it can then I’ll do the calibration for you.
