Just bought a DJI Osmo Action 5 Pro and thinking about buying another one and start using ActionStitch.
Is there a mount diagram for Action 5?
If I order it from craftcloud3d.com which material should I use? I’m planning on connecting the mount to a 1/4" tripod adapter
Just a quick update.
I ordered a mount from craftcloud3d.com based on the Osmo Action 3 file and it doesn’t fit.
I tried with or without the protective frame but no luck.
For now I will try using a dual mount bracket such as this one
I was wondering how should I position 2 DJI Action 5 (90 degrees or less)
I apologize for the wrong information. Apparently I was browsing that page on my phone and didn’t notice there were slight differences in the dimensions of Osmo Action 3, 4, and 5.
However, I think you can use a heat gun or hair dryer to “soften” the 3d printed mount to make it stretchable and then you might be able to fit the camera into the mount. Even hot water may work too.
Hi I would like to know if this camera dji osmo pro 5
Have the fov boost lens for record 180 degrees you don’t need 2 cameras, just put it on tripod.
It’s correct?
