Hi, is there a way to edit the bitrate of the output file when it is created?
Thanks
Thanks
If you download version 1.0.3 from ETA release for the next version with selectable export bitrate - #3 by gchen, you’ll be able to set the bitrate.
Great! Thanks, great product! I was also wondering if there’s a way to set the aspect ratio to align with the pitch line closest to the camera? Sometimes the line gets bent because of the camera angles so it looks a bit weird. Thanks again!
The curve pitch line is a natural result of the 180 degree view – you can’t change that by setting to a different aspect ratio.
If you really want to get rid of that, open the video using GitHub - gilbertchen/actionstitch-player: 180 degree cylindrical video player and then switch to the Perspective Mode.
