Pixellot air support
hello
is it easy to download the files from the pixellot camera?
i think to buy this camera without subscription
thanks
I wouldn’t suggest it because you need to login to your pixellot account to make the camera start and stop recording. If the camera isn’t linked to your account you won’t be able to control it. I ended up getting rid of mine because of this.
ok i understand ,i have a reolink duo 3 poe recommendation once sport but I am not satisfied with the sharpness of the video in the example of once sport its look good that’s the reason im search for camera.
Hi Vince how did you pull the file from Pixellot. I have one but everytime I connect it via usb to my computer it shuts down
Hmmm. it’s been a while but I think I found the IP address from my router and went to it like a share drive \192.168.10.XX\ and then the files were in the folder structure somewhere
How did you get the username and password once connecting to ip?
if the connection to the camera is the only obstacle, it’s not as annoying as all that
So you mean that if i buy a Pixellot Air camera i can record without subscription ? So i can have a better quality than with a Reolink Duo 3
Hi matisfr it’s very interesting if it’s possible, how is you video from reolink which settings you use specific the image stitching?
Thanks
Eran
From what I’ve read, you cannot start recording on it with the mobile app without a subscription.
Hi, where you read it? It’s for sure?
I dont have any camera yet. But i know that the quality of the reolink duo 3 is not at all on the same level as Pixellot Air, which is normal the Reolink Duo 3 being a security camera.
I plan to buy one for next season, so if i can record with Pixellot having no subcriptions i would buy the Pixellot, if not i would buy Reolink
There is no one confirm that we can record with pixellot without subscription.
The quality of the reolink is ok, of course it’s not veo or pixellot for me what I don’t like the reolink is everytime I want to record I need to set the image stitching.
Download the Pixellot Control app, not Pixellot You. The control app is what is used to connect to the camera and start/stop recording. If you can log in to it you may be able to connect to a camera and record.
I got rid of the camera a while back so I can’t test it.
But the question is if you can log in without a subscription.
That’s why I told you how to test it for yourself…
I’m also don’t have the pixellot camera
I downloaded the pixellot control app but can’t login if you don’t sign before. Only if you purchase it you can. The only thing I can think is if you have before an account and it’s ended maybe you can still log in.
So Vincerules try it yourself or if you want send me your login account if you don’t work with it any
