Good morning. I am curious to know if anyone has insight on a way to set the GoPro (11’s in my case) spot metering default points? I manually set mine to the inside lower part of the cameras every time I set them up, but would love to be able to preset them and have them stay that way (so I would have fixed left and right cameras). I am using GoProLabs in order to utilize a power bank for the power source, but I was unable to find a way to use it to set a reoccurring spot metering location. I can make QR codes that SAY they move the spot meter point, but haven’t been able to verify it actually moves them. Any ideas?
PS I realize that may have been a little vague. I know how to set the spot metering each time I use it. I am trying to find a way, if it exists, to have the spot meter set a specific point on each camera by default at startup (other than center). Would just make the rig that much easier to use.
I don’t think there is a setting for that.
I don’t think so either. Was just hoping someone had a sneaky trick in order to force the point to stay put. Thanks though.
