Hi, I am trying to export the video file and I got this error for the second time.
Do you have any idea?
Thanks .
This looks like it ran into a problem when trying to extract the audio track from the source video file. The log file should have more information. On Windows the log file is C:\Users\<username>\AppData\Local\actionstitch.com\ActionStitch\actionstitch.log . On macOS, the log file is /Users/<username>/Library/Application Support/actionstitch.com/ActionStitch/actionstitch.log.
You can also disable the audio to see if audio is the problem.
Thank you for the quick response. It’s strange because I stitched one clip at time and it was ok. When I tried to put together different clips I got that error.
If you select right audio for the stitched video, that might be the problem because there is a bug in the offset calculation. Switch to left audio if that is the case.
I am using the left channel and it’s ok. do you know any analytics software for soccer?
Thanks!
