I’m interested in getting two mission pro cameras for the large sensor size, even if I’m not going to use the highest resolutions for recording soccer. Is there an stl file for a mount, and would the software work with video from that camera model?
ActionStitch would certainly work with GoPro Mission 1 cameras, but I wouldn’t recommend, simply because of the cost. The improvements over DJI or Insta360 cameras are marginal and the cost is much higher.
If you really want, you can record a calibration video and I’ll create the calibration data for the camera. The instructions can be found here: GoPro Hero 13 Support + Mount - #2 by gchen
I have two mission 1 pro cameras. I will get a calibration video soon to send out. You need active cooling if you do 8K 60 FPS. They overheat in ~30 minutes in 90 degree ambient. I created a simple mount without tilt since I have a tilt adapter. I’m going to build an active cooling box that will allow external power. Recording in 4K 60 fps will be ideal for low light scenarios as the sensor is really good in 4K mode in tough lighting scenarios.
I uploaded to Maker World if you have a Bambu Labs printer https://makerworld.com/en/models/2948176-gopro-mission-1-pro-dual-mount-actionstitch#profileId-3302847
STL: https://drive.google.com/file/d/1CS3NnqI-jA_j5yt77vVe3p5MiMYRrXjc/view?usp=share_link
I assume I could use any 3D printer by using the STL file?
Yes any slicer will work with the STL file and should be able to print it anywhere.
