What settings on a GoPro12 match the existing camera profiles?
I have a GoPro Hero 12 Black.
If I want to use GoPro Hero 11 Black 5.3k Standard Camera Profile, are these settings correct?
Profile
Standard (other options: HDR, Log)
Aspect Ratio
16:9 (other options: 9:16, 4:3, 8:7)
Resolution
5.3k
Frame Rate:
60 (other options: 24, 30) Should this be 30 or 60?
Lens:
Wide (other options: Linear, SuperView)
HyperSmooth:
Off
Thanks
These settings should be correct. The frame rate doesn’t matter, you can use either one but I would stick with 30. 60 may cause overheat more often or take too much time to process.
